Heren, Deze app lijkt me een leuk speeltje, maar ja 45 euro.. mijn vraag is dan ook werken alle opties ook op de E85 is de zgn sunroof het cabriodak? hieronder de lijst van opties: GM5: Anti-Theft Alarm System active not active BMWhat: Turn this function on to activate optical and audible confirmations for locking/unlocking the vehicle. GM5: Optical confirmation for unlocking vehicle active not active BMWhat: Optical confirmation for unlocking vehicle is active/not active. Only works if "Anti Theft System" is set to "active". GM5: Optical confirmation for locking vehicle active not active BMWhat: Optical confirmation for locking vehicle is active/not active. Only works if "Anti Theft System" is set to "active". GM5: Audible confirmation for unlocking vehicle active not active BMWhat: Audible confirmation for unlocking vehicle is active/not active. Only works if "Anti Theft System" is set to "active". GM5: Audible confirmation for locking vehicle active not active BMWhat: Audible confirmation for locking vehicle is active/not active. Only works if "Anti Theft System" is set to "active". GM5: Audible confirmation after closing and locking all doors and tailgate active not active BMWhat: Audible confirmation for locking vehicle is active/not active. Confirmation will occur after every door and the tailgate are closed. Only works if "Anti Theft System" is set to "active". GM5: Optical confirmation after closing and locking all doors and tailgate active not active BMWhat: Optical confirmation for locking vehicle is active/not active. Confirmation will occur after every door and the tailgate are closed. Only works if "Anti Theft System" is set to "active". GM5: Alarm sound interval sound continuous sound BMWhat: Choose between (1) an intermittent sound or (2) a continuous sound for the alarm of the anti-theft alarm system. GM5: Alarm sound long active not active BMWhat: Alarm sound is extended. GM5: Alarm with dimmed headlights active not active BMWhat: Dimmed headlights blink when alarm is initiated. GM5: Alarm with high beams active not active BMWhat: High beams blink when alarm is initiated. GM5: Alarm with warning lights active not active BMWhat: Warning lights blink when alarm is initiated. GM5: Interior space monitoring active not active BMWhat: Turn sensor for interior space monitoring on/off. Useful, if pets regularly stay behind in locked vehicle. GM5: Interior space monitoring rear active not active BMWhat: Turn rear sensor for interior space monitoring on/off. Useful, if pets regularly stay behind in locked vehicle. To deactivate the sensor "Interior space monitoring" has to be set to "not active". GM5: Tilt sensor for alarm active not active BMWhat: Turn tilt sensor for alarm on/off. Useful, if car is regularly parked in duplex garages. GM5: Panic alarm active not active BMWhat: Trigger alarm by pressing and holding the "unlock tailgate" button on the remote. GM5: Unlock with Centerlock button active not active BMWhat: In a locked car the driver and passenger door can be unlocked from inside the car by pressing the Centerlock button. After pressing the button the doors can be opened from the inside, but not from the outside. Opening them from the outside will trigger the anti-theft alarm system. To lock the car again, it has to be unlocked by either a remote or a key first. GM5: Arm/Disarm Anti-Theft Alarm System With locks and remote Only with remote BMWhat: Anti-theft alarm system is armed/disarmed by locking/unlocking the car (1) with the locks and the remote or (2) only by locking/unlocking the car with the remote. GM5: Turn off interior lighting after x seconds 0s 5s 15s 20s BMWhat: Turn interior lighting off after 0, 5, 15 or 20 seconds. GM5: Interior lighting after ignition off active not active BMWhat: Interior lighting is turned on, when head lights are turned on and ignition is turned off. GM5: Interior lighting with parking lights active not active BMWhat: Interior lighting is turned on for one minute when parking lights are active. GM5: Interior lighting after unlock active not active BMWhat: Interior lighting is turned on, when vehicle locks are unlocked with the key. GM5: Interior lighting soft on/off active not active BMWhat: Interior lighting is softly turned on/off. GM5: Interior lighting turn on with remote active not active BMWhat: Interior lighting is turned on by pressing the unlock button on the remote a second time after unlocking the car. GM5: Comfort open using remote active not active BMWhat: Press and hold the unlock button on the remote to open all windows and the sunroof. GM5: Comfort close using remote active not active BMWhat: Press and hold the lock button on the remote to close all windows and the sunroof. GM5: Comfort open without rear door windows using remote active not active BMWhat: Needs to be set to "not active" in order to open the rear door windows with the remote. GM5: Comfort close without rear door windows using remote active not active BMWhat: Needs to be set to "not active" in order to close the rear door windows with the remote. GM5: Comfort open without sunroof using remote active not active BMWhat: Needs to be set to "not active" in order to open the sunroof with the remote. GM5: Comfort close without sunroof using remote active not active BMWhat: Needs to be set to "not active" in order to close the sunroof with the remote. GM5: Close window after easy entry active not active BMWhat: If the driver side window has been opened via easy entry, the window automatically closes upon locking the vehicle. GM5: Secondary unlock not active Selective central locking Easy entry BMWhat: "Selective central locking": Unlocking the car once only unlocks the driver"s door. Unlocking it again unlocks the other doors, too. "Easy entry": Press the unlock button once to unlock all doors. Press it again to lower the driver side window. "not active": Second unlock does nothing. GM5: Secondary unlock remote 1 not active Selective central locking Easy entry BMWhat: Customize "Secondary unlock" function of remote 1. "Selective central locking": Unlocking the car once only unlocks the driver"s door. Unlocking it again unlocks the other doors, too. "Easy entry": Press the unlock button once to unlock all doors. Press it again to lower the driver side window. "not active": Second unlock does nothing. GM5: Secondary unlock remote 2 not active Selective central locking Easy entry BMWhat: Customize "Secondary unlock" function of remote 2. "Selective central locking": Unlocking the car once only unlocks the driver"s door. Unlocking it again unlocks the other doors, too. "Easy entry": Press the unlock button once to unlock all doors. Press it again to lower the driver side window. "not active": Second unlock does nothing. GM5: Secondary unlock remote 3 not active Selective central locking Easy entry BMWhat: Customize "Secondary unlock" function of remote 3. "Selective central locking": Unlocking the car once only unlocks the driver"s door. Unlocking it again unlocks the other doors, too. "Easy entry": Press the unlock button once to unlock all doors. Press it again to lower the driver side window. "not active": Second unlock does nothing. GM5: Secondary unlock remote 4 not active Selective central locking Easy entry BMWhat: Customize "Secondary unlock" function of remote 4. "Selective central locking": Unlocking the car once only unlocks the driver"s door. Unlocking it again unlocks the other doors, too. "Easy entry": Press the unlock button once to unlock all doors. Press it again to lower the driver side window. "not active": Second unlock does nothing. GM5: Automatically lock vehicle active not active BMWhat: If no door or window has been opened two minutes after the car has been unlocked, the doors automatically lock. GM5: Threshold speed for vehicle locking on ignition 4 kph / 2 mph 8 kph / 5 mph 12 kph / 8 mph 16 kph / 10 mph 20 kph / 12 mph 24 kph / 15 mph 28 kph / 17 mph BMWhat: Sets the speed at which the vehicle automatically locks all doors. For models other than E46 values 1 to 6 mean the following: 4 kph, 8kph, 12 kph, 20 kph, 24 kph, 28 kph To activate this function you need to activate "Lock vehicle at x kph" for the according keys. GM5: Lock vehicle at x kph active not active BMWhat: Automatically lock the vehicle at the set threshold speed. GM5: Lock vehicle at x kph Key 1 active not active BMWhat: Automatically lock the vehicle at the set threshold speed when key 1 is used. GM5: Lock vehicle at x kph Key 2 active not active BMWhat: Automatically lock the vehicle at the set threshold speed when key 2 is used. GM5: Lock vehicle at x kph Key 3 active not active BMWhat: Automatically lock the vehicle at the set threshold speed when key 3 is used. GM5: Lock vehicle at x kph Key 4 active not active BMWhat: Automatically lock the vehicle at the set threshold speed when key 4 is used. GM5: Lock tailgate when vehicle is locked active not active BMWhat: Tailgate cannot be unlocked if the vehicle is locked. GM5: Unlock tailgate press 1x press 2x with delay BMWhat: Tailgate is unlocked (1) after pressing the "unlock tailgate" button on the remote once, (2) after pressing it twice or (3) after a short delay. GM5: Delay tailgate unlock not active 0.2s 0.4s 0.8s 1.6s BMWhat: Unlockig the tailgate is delayed by 0.2, 0.4, 0.8 or 1.6 seconds. GM5: Comfort fold/unfold for sideview mirrors 1/3 active not active BMWhat: When holding the lock/unlock button on the remote the sideview mirrors automatically fold/unfold. In order to activate this function, set the other two settings to "active". GM5: Comfort fold/unfold for sideview mirrors 2/3 active not active BMWhat: When holding the lock/unlock button on the remote the sideview mirrors automatically fold/unfold. In order to activate this function, set the other two settings to "active". GM5: Comfort fold/unfold for sideview mirrors 3/3 active not active BMWhat: When holding the lock/unlock button on the remote the sideview mirrors automatically fold/unfold. In order to activate this function, set the other two settings to "active". GM5: Window tip function driver door 1/2 active not active BMWhat: Driver door window fully opens by tapping the window switch. GM5: Window tip function driver door 2/2 active not active BMWhat: Driver door window fully closes by tapping the window switch. GM5: Window tip function passenger door 1/2 active not active BMWhat: Passenger door window fully opens by tapping the window switch. GM5: Window tip function passenger door 2/2 active not active BMWhat: Passenger door window fully closes by tapping the window switch. GM5: Window tip function rear doors 1/2 active not active BMWhat: Rear door windows fully open by tapping the window switch. Does not work on Cabriolets. GM5: Window tip function rear doors 2/2 active not active BMWhat: Rear door windows fully close by tapping the window switch. Does not work on Cabriolets. GM5: Window tip function central switch 1/2 active not active BMWhat: All windows fully open by tapping the central window switch. Does not work on Cabriolets. GM5: Window tip function central switch 2/2 active not active BMWhat: All windows fully close by tapping the central window switch. Does not work on Cabriolets. GM5: Use windows with open doors active not active BMWhat: Windows can be used on an opened door. Only works when ignition is turned on. GM5: Continue window function when door is opened active not active BMWhat: When the door is opened while its window is opening/closing, the window will continue opening/closing the window. GM5: Power windows after ignition off active not active BMWhat: Power windows are active for another minute after ignition is turned off. GM5: Rain sensor active not active BMWhat: Turn rain sensor on/off. GM5: Wiping interval 5s 3s BMWhat: Interval in seconds for windscreen wipers in interval position. GM5: Reduce wiping speed on stop active not active BMWhat: Reduce wiping speed of windscreen wipers to speed in interval position when vehicle stops. GM5: Complete wiping cycle active not active BMWhat: Wiping cycle is completed, when ignition is turned off. GM5: Wipe delay after windscreen cleaning 0.1s 0.3s 0.5s 0.7s BMWhat: Windscreen wipers wipe 0.1, 0.3, 0.5 or 0.7 seconds after windscreen is cleaned. GM5: Number of wipes after windscreen cleaning 1 2 3 4 BMWhat: Number of wipes after windscreen is cleaned. GM5: No Wiping after windscreen cleaning active not active BMWhat: Do not wipe the windscreen after cleaning it. GM5: Head light cleaning active not active BMWhat: Turn head light cleaning on/off. GM5: Number of windscreen cleanings until headlight cleaning 3 5 7 9 BMWhat: Head lights are cleaner every 3rd, 5th, 7th or 9th time the windscreen is cleaned. GM5: Number of splashes for head lights 2 3 BMWhat: Number of splashes for cleaning the head lights. GM5: Length of splash for head lights 0.7s 1s BMWhat: Length of a single splash for head light cleaning. GM5: Delay between splashes for head lights 1.3s 1s BMWhat: Delay between splashes for head light cleaning. LSZ: Sidemarker (US) active not active BMWhat: Sidemarkers are permanently active. May need additional "Sidemarker (US)" functions set to "active" if available. LSZ: Sidemarker (US) Addition active not active BMWhat: Turn signals US-Style. This function has to be set to "active" in addition to "Sidemarker (US)". LSZ: Follow me home lights duration value 01 value 02 value 03 value 04 value 05 BMWhat: Duration of follow me home lights in seconds. To activate follow me home lights, activate the flasher, while the enginge is off. LSZ: Follow me home lights - low beams active not active BMWhat: Follow me home lights for low beams are active/not active. LSZ: Follow me home lights - turn signals active not active BMWhat: Follow me home lights for turn signals are active/not active. LSZ: Follow me home lights - turn signals active not active BMWhat: Follow me home lights for turn signals are active/not active. LSZ: Follow me home lights - high beams active not active BMWhat: Follow me home lights for high beams are active/not active. LSZ: Follow me home lights - dashboard lights active not active BMWhat: Follow me home lights for dashboard instruments are active/not active. LSZ: Follow me home lights - number plates active not active BMWhat: Follow me home lights for number plates are active/not active. LSZ: Follow me home lights - fog lights front active not active BMWhat: Follow me home lights for fog lights front are active/not active. LSZ: Follow me home lights - parking lights front active not active BMWhat: Follow me home lights for parking lights front are active/not active. LSZ: Follow me home lights - parking lights rear active not active BMWhat: Follow me home lights for parking lights rear are active/not active. LSZ: Follow me home lights - parking lights rear - addition active not active BMWhat: Follow me home lights for parking lights rear are active/not active. Activate in addition to "Follow me home lights - parking lights rear". LSZ: One-touch turn signal function one time three times BMWhat: Number of turn signals when tapping the turn signal.
