Er zijn ook berichten dat er weldegelijk kwaliteitsverschil is. Bijvoorbeeld deze. Altijd lastig als berichten elkaar tegenspreken.
Yes these are made by KW and are very popular over here in the UK. The brand is separated into three companies with quality varying slightly between them all as you might expect due to the price difference.KW - Top of the line, stainless steel, plastic spring perches (corrosion resistant), best quality internal components, twin tube, most comfortable ride, helper springs, TUV approved, enough saidWeitec - Mid range, galvanised steel, plastic spring perches (corrosion resistant), internals reported to be near as good as KW but not confirmed if they are actually the same, twin tube, ride quality comparable to KW, helper springs, TUV approvedAP - Base range, zinc plated, anodised metal spring perch, lowest grade internal components, harder springs, reported to have the harshest ride quality, helper springs, TUV approvedThe above is not to say the APs are bad, plenty of people over here have been using them through a couple of hard Winters and they are still going well but it depend if you can live with a harder ride. Personally I'd choose Weitec unless it's the race track you're buying for, then KW and the V2's at the least
