Oventruuk met E39 koplampen??
Z3tje
Hi,
FF een niet Zzz vraagje.
Kun je met de koplampen van een E39 uit 2002(facelift) ook de overtruuk uithalen??
En kun je die ronde oranje glaasjes ook verwijderen, net als de oranje glaasjes op de hoek van de lamp??
  • Reacties 8
Beetje googlen kan geen kwaad. ^_^
http://www.bmwtips.com/tipsntricks/Hella%2...f/frontlens.pdf
Installation of Clear corner lenses (Front)
Posted by John528 on the E39 Message board.
1. The first thing you do is disconnect all power to the lights.
2. Then, look down on the assembly from above and remove all four screws (bolts, really) holding the assmebly in (two are on top and two are behind (down low)). Mark the spots with a magic marker before taking the bolts out so you can realingn them when you are done.
3. Once the bolts are removed, you can slide the entire light assembly out. Be careful of the outside corner, as it is sort of clipped into the body.
4. Replace your existing corner bulbs with amber bulbs. I went to Pep Boys and showed them my existing clear dual filament bulb and they found it for me. The code for the proper Sylvania bulb was 3357NALL. It cost all of US$8.50 for 2.
4. Once the light assembly is out, carefully remove the body-colored peice of molding that is attached to the bottom. It just sort of pops off if you use a flat head screwdriver.
5. Then, begin loosening the clips which hold the lights and the plastic lenses together. There are a lot of clips, so just release them one at a time using a screwdriver. Ignore the spot welds in the plastic -- just break thru them easily.
6. When you pull the lights apart, you are ready to take the old backs and attach them to your new fronts. Because you got new glass lenses, you do not need your old ones. Pop the pieces together and make all the clips to go back together.
7. Repeat in inverse order steps 1-3. Be sure to attach the power for the corner lights (your new amber ones before you get the assmeblies stuck in place -- it's hard to reach back there otherwise.
Nou , nou... dat is ook voor t eerst, dat niemand er iets van weet. ^_^
Dacht dat er ook 5 serie rijders waren onder ons. :(
ja e34 in het verleden was gewoon trekken en duwen :D
kijk... daar komt al wat ^_^
Bedankt sledge, jammer dat het waarschijnlijk niet gaat lukken :(
Ik zie op de plaatjes van het oude model e39 dat de plastic voorplaat compleet zijn met de pinkers. :D
Alleen ziet het er wel makkelijker uit.
Toch maar even in het echt bekijken.
kijk... daar komt al wat :rolleyes:
Bedankt sledge, jammer dat het waarschijnlijk niet gaat lukken :wave:
Ik zie op de plaatjes van het oude model e39 dat de plastic voorplaat compleet zijn met de pinkers. <_<
HI
kan iemand mij vertellen.....waar ik zo een wit dingetej van hella kan kopen rond amsterdam?
graag mailen. iskahlon@gmail.com alvast bedankt
grt
raj
HI
grt
raj
In de omgeving van Amsterdam zijn heel veel witte "dingetej's" te koop!
