Checklist voor New Owners
ChrisXL
Electrics
Roof – check that it opens and closes properly and locks into place, then drive home with the roof down if poss and listen out for any squeaks. Hold the roof open/close button down long enough to check that the window go back up after each operation. Also check any key programming related to the roof.
Windows - check both including one touch function and listen for rattles, there is a known problem with window rattles*
Electric/Heated seats - check all functions
Mirrors - check all functions
Lights - including Auto light function, indicators, hazards, fogs, boot/trunk and interior
Interior central locking button - next to hazard light button
Air Conditioning - including heating and demisters as soon as you can
Alarm - this isn't standard in all countries but if you have it, check that it is working
Radio/CD/Ipod
Radio
CD Player
Autochanger if you have one (take cds with you)
Check any Ipod connections
SatNav – test it!
Multi Function Steering Wheel
Volume Controls
Track/Station Change
Telephone buttons if Bluetooth fitted and phone connected
Bodywork
Check for scuffs, scratches, dents, stonechips and bumps in paintwork including the favoured place of whacks, under front skirt. Run your hand under where you can't see.
Wheels
Alloys - are they the correct ones? Check for any scratches or marks from kerbing
Locking Wheel Nuts have they been fitted (general consensus is these should be FREE)
Tyre pressures - generally this is 33psi front and 36psi rear but check as the tyres are pressurised to prevent flat spots during shipping and dealers sometimes forget to adjust them.
Valve Caps - there should be 4!
General
Chrome exhaust tips - fitted properly?
Filler cap cover - give it a firm wiggle to make sure it's not loose**
Keys - check both work
Brake light on boot/trunk – check for cracks as this is known to have a weakness***
Boot - for the first week check it's shut before you drive off, it's very easy to hit the boot release button on the key by accident
Boot release - in driver footwell
Steering Column - check adjustment
Miscellaneous
Options/Accessories - If you've ordered any other options , check they're fitted and that they work e.g. cupholders, cruise control, PDC, TV, wind deflector
Key Programming - Get any key programming done that you required and check that it works. See this thread for a list
Manuals - Make sure you have all of them and your V5 before accepting the car
Hidden paint chips/roughness - Run your finger around the edge of all shut lines etc to check for paint chips.
Inside boot/trunk - ensure all safety equipment has been supplied
Rain Sensor - If it’s not raining, pour a cup of water on the sensor behind the center rearview mirror after activating the system. Check for any air bubbles behind the rear view mirror from the outside as these can affect the RS operation
Headlight Washer - standard on 3.0, option on others
No Model Inscription - check if specified
  • Reacties 0
